2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T16:18:14+00:00
    I just took mine out of its bag and it was hot and on a blue screen stating it had not started properly.
    Previously I had set it to hibernate using a desktop shortcut
    I willing to accept the power button may have been pressed in the bag but the case **** on and closed. however I'm so getting sleep issues so this is likely to be yet another after the so called fix.
    2016-02-20T16:30:06+00:00
    Mine doesn't wake either.
    2016-02-20T18:06:29+00:00
    Got SP4 2/17. Installed update. Still have the issue. Did a reset of Windows and installed update again. Issue persists. Do have to hold power to wake. Seems to happen more often when the keyboard is attached.
    2016-02-20T19:33:15+00:00
    During Sleep, something seems to be running as the unit gets warm.  For some the fan even comes on.  It's been suggested this is from keeping WiFi on during Sleep.  But what about plugged in with an Ethernet connection?
