2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T07:56:21+00:00
    me too
    2016-02-20T08:42:39+00:00
    I don't think the update did anything. After I updated it with the recent 2/17/16 update, my surface 4 went into sleep mode and I wouldn't turn on. I had to reboot it by holding the power button.
    2016-02-20T08:59:51+00:00
      I had the sleep trouble. Frequently I had to do window-P twice, or alt-cntl-del, or sometimes hold down the power button for 30 seconds. Eventually I set the power button to hibernate. After the 2/17 update, however, it all appears to be working much better. I've had a few cases where the screen didn't come one but the keyboard backlight did, but a press of the power button (which turns off the keyboard backlight), and then a second press has brought it back.
      So for me, it isn't perfect, but it is much much better now.
      Also, it seems not to burn battery the same way when it is asleep. I've not tested that carefully yet, but will get a chance as I travel next week.
      Oh, and I do have windows hello turned on.
      Cheers, Gordon.
    2016-02-20T15:28:57+00:00
    I purchased a Pro 4 yesterday. I haven't installed anything on the machine except for the Windows Updates which include the 2/17 firmware update.
    I put it to sleep a few times yesterday and it woke fine. However this morning I experienced my first "Hold Power for 30 seconds" to wake it up. It had been in Sleep for about a hour. This is pretty lame especially for a work machine of this price.
    I had asked the MS Store yesterday about the issue, salesperson seemed to have no clue. She just offered me to exchange it within 30 days else its warranty process of getting a refurbed unit.
