2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-20T03:28:51+00:00
    Agreed.  I guess someone at Microsoft figured the best way to make us satisfied with the incredibly poor quality of the previous firmware was to push one on us that is arguably *worse*.
    As someone who formerly headed up all software/firmware for Dell's laptop brands (so I know a little bit about the complex vagaries of OS/firmware interactions, especially in power management code), I cannot for the life of me see how this ever got through even the most cursory tests, much less got released to every SP4 and SB out there.  Given the number of complaints I see in these forums (there are dozens of topics that boil down to his issue), I simply cannot believe that there was any competent testing done on this firmware upgrade.
    Unfortunately, I don't think there's any way to back out firmware "upgrades", so it looks like we're all stuck for months again while they try again.  This is quite simply unacceptable - THERE IS NO EXCUSE POSSIBLE FOR THIS CLUSTER FOXTROT - PERIOD.  And I can't even imagine anything that could make this right to SP4/SB customers now.
    Several someones at Microsoft should lose their jobs over this continued debacle - can this possibly end in anything other than a very hostile (and possibly quite well-deserved) class-action lawsuit now?
    I really *want* to love my Surface Pro 4, but it appears that Skylake cannot be made to work, and the promised capabilities and performance are not only not being delivered, but markedly worse than the SP3, and continually degrading in the SP4 and Surface Book as time goes on.
    Shame on you, Microsoft and Intel, for selling us hardware and software that is incapable of delivering even the most basic laptop/tablet functionality.
    Shame on you for not owning up to and communicating the ugliness of this situation clearly, and shame on you for making us wait many months for a "fix" that addresses some problems, but at the cost of breaking other things that are even more fundamental.
    After going through SEVEN Surface Pro 3 or 4 units in only a little over a year (three of those were totally unacceptable refurbs from MS support), I've totally lost faith in both Microsoft and Intel to deliver on their promises and stand behind their products.
    2016-02-20T03:54:39+00:00
    wonderfully for the very first time, it worked—woke from sleep with the keyboard attached. I'm in raptures. I have noticed it behaves better without the keyboard attached (twice).
    Talk about love-hate...
    2016-02-20T04:13:02+00:00
    To Consolidate Users Experience, I upgraded my display driver to avoid sleeping issues to no. 4380 before the update.
    I just want to know after installing the Feb 17 update, the display driver for Intel Graphics Driver rolled back to driver no. 4352 (not remember to exact no.)
    Some users suggested to the current driver (i.e. 4352) works well with the Feb 17 update
    Some users suggested to re-upgraded to 4380 to have better performance.
    Which driver should I installed for Intel graphics to have the best performance relating to the wake problem?
    2016-02-20T05:01:41+00:00
    Experiencing the same and I’m also exacerbated from these updates. After a snafu with the SP2 update that caused similar problems, I had hoped to avoid updates for good. I made good with that promise with the SP3. But with SP4 and Windows 10, avoiding updates is very difficult. But because I have the phantom touch problem, I’m in need of a proper update to fix it.
    Fortunately pre 2/17/2016 update, I had no issues with sleep and only occasional issues with heat (always found a culprit and found rebooting fixed it). Immediately after the update my SP4 changed.  At first I thought it was a one off crash when the power button was unresponsive to wake. Then I thought it was related to my keyboard cover.  Pre update I may have had 1 or 2 nonwake experiences ever. Now it happens 5 times a day.
    One observation is that under the new update, “sleepstudy” showed that my system is, for the first time, running in a low power state while asleep. I’ve never seen that before. I wonder though, if the new low power state is causing the difficulty in waking.
    Fed up with another hard reboot because of the non-responsive wake, I attempted a restore. Note, given my aforementioned desire to avoid certain updates, I’ve invested in understanding the use of ‘wushowhide’ where I can hide unwanted updates.
    I checked the drivers and noted their January dates. Then performed a system restore. Dates rolled back to November.  Great!  Feels like the computer I had before the update.  I hide all the firmware updates – but apparently I couldn’t hide the one referred to as ”system hardware update 2/17/2016”. Before I knew it started to install.  My display adapter date changed to January.
    I don’t know if I will experience continuous wake issues but after several short tests and a 30 minute test, I hadn’t experienced it yet.  Now what has me curious is if the new wake issue is related to the new low power state – which I believe I was able to roll back as evidenced in the sleepstudy.  Note the update caused the green low power state and at a Power rate of 38 mW which experienced a wake crash.  Now, I’m back to the numbers I have come to expect with the 350 mW rate and no crash.
    I wonder if anyone here might have thoughts on this theory. Of course, I still may experience wake issues after posting this. So this is just a preliminary theory.
    I would not recommend to anyone to system restore as I do expect some fix eventually.
