2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-19T14:56:42+00:00
    Kind of doubtful, Kevin. The issue lies in the software, not the hardware, so if you install any updates on a new machine you will likely end up right back where you are now.
    2016-02-19T14:58:00+00:00
    In the hopes to help debunk this wake issue, I want to report that after the 2/17/16 firmware update, my system started experiencing wake problems.  I did not have this issue before the update (note, I did not apply the facial recognition sign-on).
    But, I experienced a different problem where upon wake I’m forced to sign-in - despite having this feature disabled (started a separate blog about this).   I read others, having this same issue, used a registry fix.  I used it and it worked - both the Lock Screen and sign-on screen were no longer present upon wake – this mimicked my system’s behavior before the update.
    But, I lost stability and several times, after my registry change, the system would not wake from sleep.  I’ve reset my registry to pre Lock Screen/sign-on screen fix and my system is waking like normal – just I have to experience the Lock Screen/sign-on screen each time.  I’ll take that over not waking at all.
    2016-02-19T15:00:07+00:00
    I'm testing a new beta driver from Intel on my Surface Pro 4 i7. I have the intel iris 540 graphics. I'll post my findings with links to the driver and installation if it works.
    2016-02-19T15:44:21+00:00
    Confused. I was the one started the thred. Now my Surface pro 4 was turned off for 9-8 hours since yesteday and it started direct  after one little click on Power button. Put it to sleep and let it stay there (cover also closed) and after 12 minutes it started again after one click on Power button. Need to test more. Yesterday I tested alot and had huge problems like we all had. Got one little Win 10 update last night. Could that have set something straight?
