2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-19T14:02:43+00:00
    So I have checked this and all of my updates have successfully installed. But still having the issue. I also have experienced finding my SP4 very hot in my bag after falling asleep for an extended period. Hibernate seems to be better. I have also found that when it goes into hibernate I have to wait a while or press the power button 2-3 times for it to wake up
    2016-02-19T14:07:29+00:00
    It seems to do better when set to hibernate, but that is annoying.
    I was planning on swapping this device out for different hardware, but reading how many people are suffering this issue I think that might be a waste of time. Please fix this issue MS and cure an otherwise great device.
    2016-02-19T14:17:39+00:00
    As of 2/19/16, with all updates installed (including the 2/17/16 release referenced above), my Surface Pro 4 is still doing the same thing.  As I came down this morning to wake it from sleep it acted exactly as the OP described and required a forced reboot.
    Josh, was this a partial fix and are more on the way to keep people from having to reboot their tablets all day?
    PN
    2016-02-19T14:54:03+00:00
    In the meantime while we wait for MS to acknowledge that the update further screwed up Surface devices, you can either roll back the update via restore, or go into Control Panel > Hardware and Sound > Power Options - then change the "lock/power button" and "close lid" functions to hibernate instead of sleep; this way you don't lose what you were doing when you wake the device with the power button.
