2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-19T12:51:03+00:00
    Post 2/17/16 firmware update I now have the problem. Once the screen powers off and I return to wake the screen up it will light the hello camera and the keyboard but it will not come back on. I have had to power it down via the power button. The service is not set to do any power saving while on AC except shut off the screen.
    2016-02-19T12:54:45+00:00
    You need to address this immediately Microsoft
    2016-02-19T13:22:18+00:00
    This.
    Wait two months and this is the result? By this point they should have plenty of returned units to use for testing. 😛
    2016-02-19T13:26:48+00:00
    Having the same problems on Surface Book i5. You should really take down that update, Microsoft. Many, many people (self included) can't wake their device without a hard reboot since the 2/17 update. If any moderators are on, please do your best to at least confirm that this is being addressed. Enough of the cookie cutter stuff asking if we installed the latest updates. THAT IS WHAT BROKE IT! If anything, you should be instructing people how to roll back the update (yes, I know how, but many ppl don't). Anyways, not trying to jump down your throat, as a community we just want to know this issue has been reported to the devs, and that it's being looked into. Thanks.
