2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-19T08:42:47+00:00
    Me too. before the 17th Feb  update I could easily get through a day (including notes in quite a few meetings) and no plug in in- between. Still have some left for browsing on the couch at night (SP4 i5, 256gb)
    Post update, I am now lucky to get through 2 meetings. Today started at 100% charge, screen at 50%, power plan "balanced" and switched off. Switched on around 10am, put to sleep to go into meeting. Had one meeting in which I took no notes, Pressed power button (sleep) and closed type keyboard. Opened to go to meeting at 3pm... Have "stay connected to wifi while on battery" unchecked  Only 6% power.. S(*&&*^&%T !!
    Now what???? These units are not delivering what was advertised and what we expected by our "in good faith" purchase
    Microsoft, listen to your customers, respond, please provide some sort of customer service, don't put your head in the sand and let  Panos tell us publically he is reading the posts plus give all the fancy words.. Come out and say what you are doing/come clean if you can't fix it and we will all return our units and move on.. or start a class action claiming for wasted hours
    2016-02-19T09:01:12+00:00
    Yep, I got the "black screen of death" first time I closed and open keyboard. Also when I closed keyboard the surface stayed warm for some time so I suspect did not actually sleep. Opening and closing keyboard several times finally showed the hello login screen.
    2016-02-19T11:26:41+00:00
    I do not have the sleep issue as I have only ever used hibernate on the SP4. But battery life is now a disaster compared to before the update. On mains Power fan hardly runs at all but when used on battery fan runs all the time and CPU usage fluctuates wildly, even with no applications running. Before Feb 17 update I could get between 5 and 6 hours battery life, now it can just get between 3 and 4 hours at best. Plus the battery life indicator, in terms of hours left, is now useless as it varies greatly in its predictions minute by minute. But battery drain is consistently high, probably due to excessive CPU usage, hence the fan running non-stop.
    2016-02-19T11:58:07+00:00
    Been using the hibernate option and haven't had any problems waking since Thanksgiving, except Hibernate doesn't always wake properly.  But now with the update, Plugged and docked, I tried SLEEP.  it was waking fine from sleep last evening, and I let it sleep all night.  This morning, it did wake up! Yeah! BUT, it was definitely warm and as soon as it woke, the fan came on for a couple minutes.  I don't believe it is really sleeping!  I am going back to hibernate because I don't like it being warm perpetually when I think it is sleeping.
