2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-17T14:21:59+00:00
    I concur - downloading the drivers is a placebo. The video driver version (4308) in the download referenced above is the same as on a fully-patched SP4 from windows update.
    2015-11-17T17:18:49+00:00
    Having the same issue, downloading the driver listed above does nothing.
    2015-11-18T00:31:54+00:00
    Power plan is balanced, set to all defaults right after the TH2 update this weekend.
    I undocked my SP4 and took it to a meeting but didn't have to use it. When I got home woke it briefly (~1 minute) and then closed the keyboard to have dinner. When opened the keyboard, the lights on the kbd came on, but the screen wouldn't wake. I tried clicking the pen eraser, but the screen didn't wake. I tried a ctrl-alt-del and got a charm sound, but no screen. Clicking the power button turned the keyboard backlight on and of but the screen wouldn't revive. After 10 minutes I power-volume reset the machine and restarted after dismissing the bios screen.
    When I got back to the desktop, I had 70% battery. This was (roughly) 3-3.5 hours from when I undocked it.
    Sleepstudy showed 11% battery discharge per hour in the two sessions, with the first being dominated by a USB controller (~70%), with HD520, CPU/CO, and Marvell all clocking in at around 20%. The second session was dominated by the WP Sync Client (I don't have a WP phone, fwiw) at 67% with BI and HD520 each clocking in at 20%.
    Note that, to my memory, my SP4 has never woken up by just opening the keyboard, I've always had to click a key or the track pad, or press the power button.
    Certainly this can't be the intent of connected sleep. Any suggestion on how to mitigate this carnage?
    2015-11-18T21:14:45+00:00
    I've had exactly this too. Before the usual response to these problems, my device is completely up to date with updates and I've not touched any of the power plans. Hoping that a firmware or driver update fixes this issue.
