2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-17T08:56:12+00:00
    The correct link should be http://www.microsoft.com/en-us/download/details.aspx?id=49498
    The one above would not work because of the dot at the end ;-)
    2015-11-17T09:24:57+00:00
    It really seems that this fixed it, I recommend downloading the sp4 driver pack(msi)
    UPDATE: No it did not fix it.
    2015-11-17T13:04:00+00:00
    Have you tried to put your device to sleep for over a few hours. (basically, close your type cover when screen is on and leave it there overnight) and see if you can wake it up after
    Coz I have downloaded the same drive pack and installed, it didn't make a difference on this issue
    2015-11-17T13:26:17+00:00
    These are the same 11/02/2015 drivers (SurfacePro4_Win10_151102_0.msi) that everyone already has and they don't fix the *VIDEO_TDR_TIMEOUT_DETECTED (117)*issue upon waking up from sleep.
    Microsoft tech support is clueless and just gives out standard scripted answers. This is a driver timeout issue upon waking up from "sleep" and needs to be fixed by the Microsoft Surface Team.
    In the meantime, you can go to Control Panel -> Hardware and Sound -> Power Options -> System Settings and set everything to Hibernate (or Shut down) as shown below:
