2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-08T12:16:23+00:00
    Your answer is pretty much incomplete!
    The text you had written is not the answer, you should describe more in details about the problem, and suggest a temporarily solution. Not just go straight to say hey do that...
    I appreciate your responsibility to community, but for someone like you with those badges more responsibility and professionality is required.
    2016-02-08T19:12:49+00:00
    While sleep mode still has problems, is there a way to completely disable it? I can pretty much count on the machine being broken and crashing sooner or later after going to sleep. Last night I had it connected to the dock and only closed the keyboard so it can continue downloading stuff for a while. I've set it not to go to sleep when on battery, do nothing when closing the keyboard and hibernate after 30 minutes. Today when I resumed from hibernation, it crashed shortly afterwards, I checked the logs and discovered that it awoke from sleep at some point in between. For some reason it still sleeps even though it's supposed to be disabled.
    2016-02-08T19:29:22+00:00
    I have the MSFT recommended driver (whatever shows up with updates), and with an I5 256, have had no problems in several weeks with Sleep wake issues or fan issues.  What I'm noticing on this board is that folks having issues always mention closing the keyboard.  I never do that, so I can't comment on it.  But I'm wondering if that is the residual issue, putting it to sleep via closed keyboard.
    My issue with sleep is that it gets warm DURING sleep.  So I now use hibernate for times greater than 2 hours.  I don't like it, as coming out of hibernate is not nearly as simple as coming out of sleep. My SP3 goes in and out of sleep with the power button like a charm.  My SP4 seems to do the same now, except then it gets hot.  I've not seen anyone comment on the getting hot issue during sleep.
    Does anyone know a way to determine what is or was running during the time it got warm?
    2016-02-08T19:34:27+00:00
    The sleep problem is definitely *not* just a closing keyboard issue. It has same issues when you hit power button (that's not just for me, many posters have the same issue regardless of 'how' it gets to sleep).
    I do also have the problem where it gets warm when it's supposedly sleeping. Unfortunately, I have not seen a solution for that one.
