2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-07T19:54:30+00:00
    Just now my Surface was sitting around with only Edge and Mail open, basically not doing anything, while I was watching some YouTube video on another computer. Since the Surface's fan started spinning up all the time, although there was no considerable CPU or disk usage, I decided to let it sleep by closing the keyboard cover.
    A couple of minutes later I opened it up again and, guess what, nothing.
    I tried CTRL+ALT+DEL, WINDOWS+P, both did not work for me. Had to shut it down and restart again.
    My video driver version is still 20.19.15.4326 and frankly, if it's not been released officially by Microsoft yet, there probably is still something wrong with the newer drivers. Given the state of the current release versions I don't really trust them to deliver a functioning set of preview drivers. And from what I am reading here, we are nowhere near a solution to this problem (with neither driver version).
    2016-02-07T22:47:40+00:00
    LauraMer, the driver on Intel's website, mentioned back on (I think) page 42 of this thread, is 20.19.15.4352.  I've been using that for over a month now.  My wake issues have been limited to maybe 2 or 3 times over the last month, if that.  I use Ctrl-Alt-Del pretty regularly though.
    From what I've read here, the .4352 driver doesn't work well with the dock, but I don't use the dock.  Intel makes the video hardware, and the driver.  I'm sure MS has their reasons for not rolling it out - maybe because of the dock issues - but that wouldn't dissuade me from using it.  It's made the difference between a having a Surface vs a brick.
    As an IT Pro and long time (30+ yrs) Microsoft user, I have long since stopped looking for logic and rationale in what they do, or don't do.
    2016-02-08T00:25:36+00:00
    Been using this driver for a few weeks, problem has cleared up,  no problems with dock.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8c63985a-d00d-4cf5-834d-3c75f064b072)
    2016-02-08T00:32:37+00:00
    That is the one that largely fixes one problem and creates another -- can't connect to an external monitor.
