2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-04T21:52:53+00:00
    Ctrl-Alt-Del does not help (for me).
    2016-02-05T01:31:51+00:00
    I have the beta driver and have also experienced the illumined keyboard + dark screen issue a few times. The screen came back when I used the windows key+P combo (pressing 2x) ....
    2016-02-06T22:24:01+00:00
    My Surface Pro 4 has locked. I have tried to shut it down but it won't shut down using the power button. The screen will go black but if I move the mouse the sign in screen comes back up.  I let the battery die hoping it would unlock but that didn't even help. It is locked on the sign in screen. I have only had it for a couple of months.
    2016-02-07T00:36:57+00:00
    Find the solution in this thread. 2 button reset
