2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-03T20:24:21+00:00
    Results of my tests/experimenting are similar to the group. I did manual update to Intel driver and my sleep issue seemed to have gone away. However, similar to those who reported dock issues, while I don't use a dock, I constantly plug into an external monitor. AND, with the new driver that fixes the sleep problem, I can no longer attach to an external monitor.
    Microsoft, please get off you butt and fix this once and for all!!
    2016-02-04T16:09:50+00:00
    I have the v20.19.15.4352 and the screen still will not wake up.  The keyboard lights up but screen remains dark.  I am currently shutting down Windows before I close the keyboard because I don't like the hard shutdown method.   Very painful with no solution yet.
    2016-02-04T16:18:25+00:00
    In this situation, Ctrl-Alt-Del should be all you need to do.
    2016-02-04T21:44:31+00:00
    I chose NOT to get that new driver, and am not having any fan issues now, or Sleep wake problems.  I am mostly in pc mode, not tablet.  If you still have the problem after the update, I wonder if you would be better off with the old driver they are still suggesting we use.
    I have two residual problems no one else seems to complain about:
    1. SP4 docked is running hot after several hours IN SLEEP
    2. It won't wake requiring a password every time, but does if required after 1 minute.
