2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-02T21:10:11+00:00
    I have seen some posts that the new drivers do not work with the Dock and a desktop monitor.  And since Microsoft did not include them with the new update, I suspect it may not help those of use equipped this way.
    I can confirm this. I installed the new drivers over the weekend, system worked great. Today I put it in the dock, had to reboot to get the system to connect to the dock's monitor. From there I went to a meeting and had to reboot before the system would display to the projector. Not good.
    2016-02-02T21:29:34+00:00
    I strongly recommend you download the latest display driver from Intel.com and install it.  It fixes many problems and has eliminated the sleep mode blackscreen problem for me.  Installation is a little complicated.  Follow the instructions found on page 42 of THISthread.
    2016-02-02T21:35:37+00:00
    Ok, I see that the graphics driver was put back by the firmware update so I need to manually reinstall. Makes me feel better as I did think that new driver fixed the sleep issue.
    That's interesting.  The firmware upgrade from a few days ago did not touch my manual install of the Intel x.4352 Dec 2015 driver, it remained installed/active.  My SP4 continues to wake from sleep perfectly probably 95% of the time, the other 5% it is a bit sluggish and/or I have to tap the power button once or twice extra, and occasionally the Windows Hello camera red light comes on doesn't seem to want to go off without some gyrations.  But mine's a million times better than it was in December. And in reference to some other posts, my battery life hasn't changed since the firmware update, it continues to be pretty solid.  I manually dial down the display brightness as much as possible, though, which I'm sure helps.
    One tip of the day for those who may not be aware, it's my favorite one to tell SP4 and SP3 users about -
    Fn+Del increases display brightness, and Fn+Backspace decreases display brightness.
    You could do it one-handed with the SP3 keyboard when the Fn key was on the right side, now it requires two hands with the SP4 keyboard.  Sorry about the off-topic digression...
    2016-02-02T23:53:49+00:00
    You just made me happy!  I've been wondering why the keyboard doesn't have this obvious function, as I reach for it often.  And now I have it. : ))  Thanks!!
