2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-01T23:58:09+00:00
    This works for me, BUT... it happens CONSTANTLY. Basically if I shut it off, I might as well power it down every single time because I have to do this two-button restart 50% of the time. A royal time-consuming productivity buster. Either I have a lemon or this machine is seriously flawed. All updates installed, etc. Surface Pro 4, i7 512GB. What a great machine save this very serious problem.
    2016-02-02T00:35:33+00:00
    You can find the instructions on Page 42
    This new driver works.
    I have not being able replicate the problem, it always wakes up now.
    BUT, It seems like battery is draining faster than before....
    2016-02-02T02:09:15+00:00
    I have seen some posts that the new drivers do not work with the Dock and a desktop monitor.  And since Microsoft did not include them with the new update, I suspect it may not help those of use equipped this way.
    2016-02-02T12:29:47+00:00
    I just had the problem where the screen does not wake from sleep and I get the mouse pointer on a black screen. ctrl-alt-del gets me back on.  This is the first time I have had the sleep problem since updating the display driver.
    I verified I still have the latest Intel driver that I manually installed. So...I'm disappointed as I thought the problem was fixed.
