2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-17T01:04:30+00:00
    Split from this thread.
    Hello.
    I have just bought a Surface Pro 4 with a type cover , and am having similar problem waking sometimes.  This usually happens when it has been asleep, for an extended time, maybe in hibernation.  I then have to hold the power button for 30 sec, then turn back on.  Sometimes it will not start unless I remove the type cover.
    It has installed the latest WIndows 10 major update, with no improvement.
    Also it sometimes completely freezes, ignoring anything I do with the touch screen or type cover keyboard.  This requires shutting down with the power button the restarting.
    Thanks for any help on this.
    Ron
  2. Deleted
    2015-11-17T06:00:56+00:00
    The download must be tailored to your account.
    2015-11-17T06:56:03+00:00
    Have you tested it? Because I don't think so
