2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-01T17:07:01+00:00
    Intel makes the video chipset which seems to be where the issue is.
    OK, good point,
    Is this a hardware issue in the video chip, so should I simply send the thing back, because the chip is broken, and look for a further iteration of the product?
    Or is it a video driver issue, that will (hopefully) be solved via an update?
    2016-02-01T17:39:37+00:00
    I don't think there's anything fundamentally flawed with the hardware.  Just my opinion.  I think improvements need to be made in the drivers for video and power management.  In previous pages of this thread there is a procedure to manually update the video driver to a version from Intel's website.  This has completely solved the wake from sleep issue for me.
    You can find the instructions on Page 42
    Be sure to follow them precisely, the choices aren’t default/obvious.
    2016-02-01T18:29:21+00:00
    Really hoped that the crashes was fixed after the update last week, almost been a week without having to force reboot the computer until just now. I have had the camera frozen a couple of times so I couldn't use Windows hello and the battery drains faster than on a desktop (well did get 2-3 hours so not quite that bad but you get the point). Glad that I already decided to return the unit before it was to late, just hope I'll get the new Dell XPS 13 before I have to send this back so I atleast can get a smooth transition after all the problem that this computer has caused.
    I really think this will be a great device in 6 month or a years time when Microsoft get the software sorted out but I'm not sticking around and wait any more. The crash today really proved that we are no closer to a acceptable solution that we where when the computer launched.
    2016-02-01T19:02:25+00:00
    Better be careful if that XPS13 is also a Skylake (6th Gen Intel part). A lot of the issues with the surface seem to be Skylake related (graphics, power consumption, etc.), so I'd check the Dell support forums to make sure that they've nailed down the drivers before going with it. Conversely, now might be an excellent time to snag a great discount on a product with a Broadwell/5th Gen part such as the old XPS13 or the SP3 with Windows 8.1: Those have been out long enough that they should actually have functional drivers.
