2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-02-01T06:47:26+00:00
    For me, having previously installed the updated Intel Drivers, it seem that it got better.
    I still have issues with sleep, but less frequently than before. Sometimes though, even it comes back from sleep, all programs have been closed.
    So... of course, not really a fix, but at least a bit of improvement.
    2016-02-01T11:02:14+00:00
    This is a huge bug that makes a nive device unreliable.
    Microsoft makes the hardware and the software, it is unacceptable to have this problem on an over priced flagship device!
    This should be a priority inside Microsoft.
    Please solve this issue
    2016-02-01T14:21:27+00:00
    Intel makes the video chipset which seems to be where the issue is.  I can't believe I'm defending a tech company, lol...not that I am...but this is not a simple issue by any means.  But I would like to see more communication from them, and a greater sense of urgency.
    2016-02-01T14:36:41+00:00
