2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-29T18:10:26+00:00
    Nope the time remaining is very realistic! I can watch the % drop in increments of 3 ever few minutes. It royally messed up. Needed this for business and won't even last through a meeting!!!
    2016-01-29T18:32:46+00:00
    Pro Tip: You can achieve a perfect score of 10 if you leave a machine completely turned off for two weeks straight. The score seems to gravitate towards the high marks automatically (as you can probably tell) and you can then enjoy watching it dunk down again within hours. Fun times.
    Thanks for that, this is the first thing about my SP4 to make me smile in weeks :).
    2016-01-29T18:40:14+00:00
    Ok, the update didn't fix anything about this issue. Just returned home and I get ... nothing. Screen backlight turns on, that's it. Waited for some time, pressed the power button multiple times, pressed random keys on the keyboard, waited some more... nope, it died again.
    This is so annoying. Granted, it happens only like once a day, but in this state I might as well shut it down completely. Instant on my ***.
    My battery isn't entirely messed up though. I get 6hrs 17mins at 100% with nothing going on. Wait, now it's 8hrs, 33mins. I don't trust this laptop to survive a full day, so I always carry a charger with me. But 1 hour? That's messed up!
    I am beginning to think this reliability chart wasn't such a good idea after all. It's kind of frightening just how much red I get there almost every single day.
    2016-01-29T18:57:40+00:00
    Ctrl-Alt-Del doesn't bring the screen to life at this point?  It has worked consistently for me.  I must be blessed or something.  Ever since installing the Intel video driver mentioned in previous pages, my biggest problem is occasional use of Ctrl-Alt-Del to make the screen light up.  I have the keyboard cover connected almost all the time.  I don't use the dock.
