2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-29T01:50:14+00:00
    I am trying to use Sleep now instead of Hibernate. So I set power plan to require password when waking, and power button puts it to sleep.  I put it to sleep, wait a few minutes, try to wake it up.  So far it does wake up, BUT it is not requiring a PIN.  Anyone else experience that?
    2016-01-29T02:24:28+00:00
    Same here, Turbodogx. Just a tip: make sure it's unplugged from the wall when you're turning it off. Normal Sleep (as in not Connected Standby, on other machines) will almost always ask for PIN based on the power state in which the PC was when you put it to sleep, not when you woke it up. In other words:
    1. plugged-in -> Sleep -> unplug -> wake -> no PIN
    2. on battery -> Sleep -> plug in -> wake -> asks for PIN/password (even if plugged-in then)
    (That is if you have the policy set up differently for each power state like I do.)
    Also note that when the device is in Connected Standby, which is now the only available state except for Hibernate and Off, it will BY DESIGN turn the screen on for about five seconds when you plug in or unplug the power adapter. This is supposedly to show you the charging icon in the taskbar and to eliminate the need for an extra charging diode on the device. Go figure.
    Tip: to understand the available power states, type "powercfg /a" into your command prompt.
    I suspect our Surface Pro 4 never actually sleeps very well, if at all. You know, this is a very hard computer science problem. Today, for example, mine never properly slept, it heated up in my bag (even after the update), and then - as I woke it up - I had one "Video Driver Failed & Recovered" error or whatever it says. The battery was exhausted quickly, seeing as the CPU and fans were working all day in the bag. Thankfully, no blue screens so far. What a great advancement!
    Sleep seems very unreliable regardless of the way I switch the machine off. I have a Type Cover too. Starting to think maybe the accelerometer in the Cover (detecting its alignment / relative position with the SP4 body) wakes the device up when it's moved at all, or something even more sinister perhaps. "Fortunately", Connected Standby greatly reduces the number of devices for which you can disable "Allow this device to wake the computer" in Device Manager to only the cable-attached peripherals.
    I disabled Wi-Fi connection for both battery and plugged-in (in Settings->System->Power) so as not to irritate more devices during wake than need to be. I was hoping the update would help more but it seems that it just shuffled the cards on the type of errors we're dealt every day.
    I am still very sad :/
    2016-01-29T02:34:09+00:00
    Sorry to see your very own red sea, stlg. I had also completely forgotten about this report but was reminded of it somewhere recently. It seems to provide a nice way to summarize Event Log's System entries.
    Sadly, running this report quickly allowed me to realize that all of my Windows 10 machines are drowning around a score of 2-3 at best, with regular drops to the minimum. Woot!? :/
    Pro Tip: You can achieve a perfect score of 10 if you leave a machine completely turned off for two weeks straight. The score seems to gravitate towards the high marks automatically (as you can probably tell) and you can then enjoy watching it dunk down again within hours. Fun times.
    2016-01-29T07:43:38+00:00
    ...still the same problem after the january firmware update.
    The only information how to solve this problem is how to reboot the surface.
    This is not enough for such expensive device
    greetings, Andreas
