2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-28T17:30:13+00:00
    Mine was about 70% failure rate when it went to sleep. With the new update hasn't crashed in about 20 wake from sleeps! Looking promising......... except the battery life which seems to be a lot worse! 50% battery is showing 58mins on the 2nd darkest screen setting......
    Edit: After using groove music player for 30 mins, screen off in sleep 48% battery drain. So ****!
    2016-01-28T20:12:53+00:00
    Do you think it is SLEEP that is using the battery?  I wonder if HIBERNATE is still the better option?  It is interesting that the firmware update did NOT change the display driver from Nov. 20.
    2016-01-28T21:23:05+00:00
    Maybe everyone else knew this except me...A few pages ago someone posted a request that others post the results of their "reliability history" (I didn't know such a report existed in Windows 10, and I consider myself a fairly proficient Windows user.  To repeat what that post suggested, type "reliability" in Cortana search and the result at the top is the means to get to the report).  ANYWAY, and this is a bigger learning for me, on that report, if you click on any particular day, it will display additional information about errors and warnings that occurred on that day.  I just noticed that on mine (pasted below), the "informational" data itemized what Windows update did yesterday.  While some of it doesn't provide much detail ("system firmware"), it did list a number of individual driver and firmware updates with good detail.  See below (and also note, no red "failure" dots today!!)  Formerly I was not aware of a concise way to identify this.  If nothing else maybe some will find it interesting...optimistically maybe it will help those experiencing battery issues after this update to identify the source of the battery drain - e.g., wireless and Bluetooth were both updated.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=aea58bf0-bd40-49ff-87ca-5f6f5afc66f2)
    2016-01-28T21:47:07+00:00
    I installed the update today.  The battery indicator shows what I think is a reasonable percentage amount left based on my usage but the hours and minutes remaining change every time I click to check. Sometimes it shows 5 hours or so left and next time 9 hours when I have not changed anything and only a few minutes have passed. So...that indicator may be messed up but the % indicator is ok.
