2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-28T13:23:23+00:00
    Just installed the firmware update.  Nothing mentioned in the update about fixing the sleep issue.  I never appreciated my iPad, how it always popped awake every time I opened the outer cover.  It used a magnet to sense that, and popped on every time.  Gotta give credit where credit is due.
    2016-01-28T13:47:32+00:00
    Wh00t! 10 out of 10 sleep/awake cycles closing cover then opening it and pressing key.  Slower but works
    Once when I opened before external display indicated was asleep my 2 external displays got swapped and device display was black.
    Now to see if it really sleeps and doesn't "cook in the bag"
    2016-01-28T15:08:31+00:00
    I had the SP4 for about a month now. A few weeks ago I noticed that my SP4 wouldn't wake form sleep. It just didn't respond to me pressing the power button. Thankfully I noticed that the keyboard was lighting up, and then turned off after a few seconds. If I pressed the power button again, the keyboard would light up again, but the SP4 would still be unresponsive.
    The only way to bring the SP4 back on was to press and hold the power button for approximately 10+ seconds (i.e. a hard reset).
    I noticed that if I close the SP4 by pressing the power button first, and THEN closing the lid, I don't have any issues.
    Is there a solution for this?
    2016-01-28T15:26:13+00:00
    This issue has been discussed extensively in other threads on this forum.  The solution for many has been to download and install the lastest display driver directly from intel.com .  Please do a seach for more info.
