2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-11-16T15:16:57+00:00
    So I talked to support and they sent me the link for the surface pro 4 drivers - http://www.microsoft.com/en-us/download/details.aspx?id=49498. They said I should download the .msi file (was 170mb) , install and reboot.
    Will give an update when I tested this.
    UPDATE: This don't fix it. Tried now for a day, still wont wake up after long periods.
    2015-11-16T15:21:28+00:00
    I don't have windows hello active , only pin. very risky for me with no security. And will not pay this much and compromise.
    2015-11-16T15:34:15+00:00
    I'll confirm, I don't have windows Hello active either, but still have this problem.
    I would like an official statement from Microsoft regarding this issue and an expected resolution date.
    2015-11-16T18:06:04+00:00
    I also have windows hello disabled. This only started happening consistently after the th2 update.
