2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-25T03:41:17+00:00
    I have had mine for two days as of today and it was just fine when I turned it off last night and today ity wouldn't come on. The keyboard lights up when I push the power on button and that's it.
    2016-01-25T13:26:13+00:00
    Hi!
    Same happened to me numerous times - I already exchanged my Surface Pro 4 twice and is still happening to my latest one...very frustrating- now my 30  day return policy is up and can't get my money back.  I suggest returning it and get your $$$ back while you can!  Pressing the volume and start button for about 15 sec. at the same time  and pressing the start button again right after again seems to help, but still frustrating.  Also, the freezing problem is a big issue, too, and happens to me frequently...I really liked the idea of the product and wanted to get away from Apple, but I'm already regretting my decision.  I need a reliable computer and this is not working for me, but now I'm stuck and just have to wait for them to finally fix the problem.
    2016-01-25T13:27:15+00:00
    In this scenario, Ctrl-Alt-Del usually wakes up my screen.
    2016-01-25T17:57:38+00:00
    I have not had this problem for 5 days since updating the display driver.  Have you tried that yet?  It was easy to do and seems to have resolved the issue. I'd be interested to know though  if anyone has updated the display driver and still has the sleep issue.
