2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-23T22:07:52+00:00
    this actually as good as fixed this problem :)
    Thanks mate!
    2016-01-23T22:45:22+00:00
    Hello Marcin, which early january driver update do you mean?
    https://www.microsoft.com/surface/en-us/support/install-update-activate/surface-pro-4-update-history
    thx,
    R
    2016-01-23T23:28:13+00:00
    thx,
    R
    The one that was rolling back one of the f**ked up drivers from December 2015 ;).
    So yes technically it's November driver - exact version: 20.19.15.4326 (20.11.2015) - it was rolled back on Jan 6th on my SP4. During the late December I had the worst one (until this "silent" rollback) not mentioned in the update history. Fun fact:
    https://www.microsoft.com/en-us/download/details.aspx?id=49498 (this driver pack also should revert driver to a usable version).
    2016-01-24T00:27:48+00:00
    Nice find!
    Yes, I discovered this download a couple of minutes ago too. Funny it has the older drivers, seeing as the date says 15-12-16, which is one day before the December 17 update.
    Anyway, these issues are really annoying. These days, I get BSOD or a turn-on-to-restart (probably a BSOD with the screen turned off) at least once every two days, probably more often. My Event Log is full of device failures, driver errors and kernel power errors. In a closed system, mind you, not a custom-built PC. The screen often does not turn on. I used the newer Intel-supplied drivers as well as the MS-shipped drivers and there may have been differences, but both came with VERY annoying issues.
    I used hibernate with disabled Connected Standby as well as Connected Standby enabled (HKLM\System\CurrentControlSet\Control\Power\CsEnabled [1/0] -> restart). Both for at least 10 days. Both scenarios caused blue screens, choppy video playback in Edge or high processor usage when a YouTube page is open in Edge (playing or not) and other errors.
    I am getting tired of this.
    One glimmer of hope which should have been shared by MS and not by accidental discovery: Surface Pro 3 just received a driver update for a lot of hardware: https://www.microsoft.com/surface/en-us/support/install-update-activate/pro-3-update-history
    If there are any hardware similarities between the two, I have my fingers crossed for a fix for SP4 soon. If not, I'll finally give up and get a Dell XPS 13 or something like that instead. This is just sad :(
