2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-23T10:00:54+00:00
    2016-01-23T11:58:41+00:00
    This seems to happen more frequently if:
    1. I have usb/display ports attached to devices
    2. close the lid
    3. unplug things (usb, display)
    4. open the lid a few seconds later (maybe a minute)
    I get a black screen and have to reset.
    This has been my observation as well.  The problem seems to still occur without plugging things in and out, but much less often.  I'm not certain, but I don't think the problem occurred at all before I reset the screen resolution and then plugged in an external monitor.  Not sure which may have been the trigger, because I did them in quick succession, but the problem became very frequent after that.  Always sending the computer to sleep with the button seems to dramatically reduce the incidence, but not eliminate it.  And the use of a secondary screen [see my post a few days ago], which works 90% of the time for me, doesn't always work.  Last night, both screens were black and I had to do a forced re-start.
    Btw, my touch screen has temporarily stopped working at the moment, but when this has happened a couple of times in the past, it comes back by itself later . . . ie without me having to restart.
    2016-01-23T20:28:48+00:00
    This is happening to me too. I just bought my surface pro a few days ago and it is an excellent device apart from this significant problem. If I can't get a fix for it, i will be forced to return it for a refund. Microsoft's response to reboot the computer every time this happens is completely unacceptable. I need to be able to use this device within seconds of picking no over one minute, having lost all my applications that were open.
    2016-01-23T21:41:14+00:00
    Have you all tried disabling Windows Hello? I disabled Windows Hello to fix battery drain issue (it works) and together with drivers from windows update (early january). It's quite OK. Not perfect, but really not that bad as it was before.
