2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-21T21:53:47+00:00
    Its not a proper fix but if you switch the power saving settings from sleep to hibernate the display issue seems to go away, it also resolve the issue of the surface remaining on when you close the lid and put it in a bag, potentially over heating or draining the battery without you knowing.
    Click on the battery in the taskbar -> Click on "Power & Sleep Settings"(this brings up the power and sleep settings in the system settings menu)
    Click on "Additional Power Settings" under "Related Settings" in the right hand pane of "Power and Sleep" in the system settings pane (which loads a new window showing the power options control panel )
    Click on the "choose what the power buttons do" on the left pane and **change everything from "sleep" to "hibernate" on the pane "on battery" and "on plugged in"**and click "save Changes"
    This should resolve the issue as a temporary fix while MS fix the sleep function which is likely a intel graphics driver issue, but it will take longer to boot each time and you'll get the surface logo each time as if the device is switched off completely which it is (hibernation mode is a complete power off but preserves the system state so your open apps will reopen as they were) .
    Note: "closing the lid" is the same action as closing the type cover.
    The trade off is that it takes a bit longer to wake but the response is consistent around the display, and it doesn't fix the underlying sleep display issue but it does seem to work.
    The sleep display issue was driving me mad. MS still need to fix it, it would also be great if I could still listen to spotify like I can on an iPad in sleep mode.. and add the additional characters missing on the soft keyboard in split mode, and the rotation issue when you use the dock, and scaling apps (why does everything in office work except lync? with scaling) and a whole bunch of other minor but very irritating issues that lead to an overall poor user experience.
    Hope this helps others anyway.
    Dan.
    2016-01-21T21:56:45+00:00
    I forgot to add to IrishFamilyGuy's post - if you were looking to deploy 200+ SP4's you could use group policy in active directory to deploy these settings consistently across your computer estate. It still needs MS to fix the issue though.
    2016-01-22T15:42:48+00:00
    So far I have had no sleep/wake issues since updating the display driver. May be too soon to be sure though since I have gone 5-6 days without the problem before,  but lately it has recurred more frequently. I'll post again later next week. I noticed also that my screen, which used to get darker (maybe the flicker issue?) when on battery only use, no longer does that.
    I have tested the sleep issue several ways; closing the tablet to the keyboard, pressing the power button, and just letting it sit idle until it sleeps. In all cases it came back ok.
    2016-01-23T07:38:46+00:00
    Returning my surface pro 4 and surface 3 seem to having the issue on both of them.
    I remeber first i was I was be trade on the surface pro 3 throttling than it also started having issues with wake and sleep.
    how can something like this still happen pathetic!
