2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-20T21:07:16+00:00
    Microsoft working on 'sleep' issues with Surface Pro 4, Surface Book with solution early next year
    I think that's a separate issue.
    It is, but my reason for posting was in response to turbodogx asking about how widespread/well known the sleep issue is.  The link mentioned that the new chipset is "problematic" in relation to the sleep issue, and I doubt the wake from sleep issue has escaped their notice.  We have a 50+ thread going here, I'm sure MS knows about it.  But I don't expect a response from them.  Eventually they'll figure it out and post a fix, which will get rolled out with an update, and they'll act like there was never an issue.  This is SOP with MS.
    2016-01-21T04:55:12+00:00
    So if I close my type cover (sleep) for about more than 2 hours, maybe even shorter but I haven't test it yet. After I push power button when I want to awake it, every time it just stays at Surface logo for about 2 minutes which is really unbearable.
    Any suggestions how to solve it? Thanks.
    2016-01-21T08:21:59+00:00
    I too have recently bought a Surface Pro 4 and experience the same problem several times a day.
    This insight may be helpful, particularly if someone at Microsoft takes an interest in understanding what is going on:
    I have found that when the condition occurs [ie keyboard wakes up but screen stays black], the primary display is available if you plug in an extension screen.  The touch screen functions, but doesn't display.  But what's really, really interesting is what the computer seems to think is happening.
    Swipe in from the right and use the mouse to select 'Project' and the 'current' setting highlighted shows 'PC Screen Only'.  Ie, Windows 10 thinks the primary display is the surface screen, but the video card is sending it only to the external screen.
    Clicking on the 'PC Screen Only' option has no effect, reinforcing that Win 10 thinks that is what is already happening.
    Clicking on 'Second screen only' also has no effect, but changes the highlighted option.  THEN if you click on 'PC Screen Only', the Surface display takes over and everything is rosy.
    This is a much more satisfactory solution than turning off and re-starting the Surface, but depends on you having a second display readily available.  Not much help if you're on the train or in a meeting!
    Would be delightful if Microsoft could have a close look at what's actually happening here . . .
    2016-01-21T09:16:05+00:00
    I have never enabled Windows Hello and initially set up my Surface to not require a password.  When I started experiencing this problem, I re-enabled the password and I can confirm that I still have the problem.  So you may be rejoicing too soon!
