2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-19T16:32:33+00:00
    @Dyndragon, this resolved the issue for me beautifully. Thanks!
    2016-01-19T21:30:57+00:00
    It did not work for me because the manual update search could not find the .inf file in the folder.  It was in the zip folder but the update program could not find the file.  I was dead in the water.
    What can I do?
    Bim Rowley
    2016-01-19T21:55:14+00:00
    My Surface cannot find the .inf file in the folder so it just gives up.  Any suggestion?
    Bim Rowley
    2016-01-19T22:52:35+00:00
    Bim Rowley
    Hello Bim,
    Make sure you have unzipped the entire package to a folder first (e.g. next to the ZIP package). Then navigate Device Manager to that folder, not to the ZIP package.
    The ZIP package is a faux folder and the system does not automatically see all of the sibling files in it, only the ones you expressly extract. That's why you must unpack everything first into a proper folder.
    To unpack, right-click the ZIP file and hit something like "Extract ..." in the context menu.
    Once unpacked, you can delete the original ZIP to prevent confusion.
    Good luck!
    R
