2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-18T23:10:16+00:00
    Agreed,
    I think MS needs to get this fixed ASAP.  I have yet to ever have any problem like this from ANY other tablet.  The fact MS built the hardware to be compatible with this OS speaks miles to the lack of QC, and testing that should have been done to make sure this stable.  I would expect this to have been a problem that's not been around for this long, but I see this issue has been around for over a year!?!?!?  WTH!?!?
    2016-01-18T23:33:37+00:00
    Agreed,
    Do you really think MS built the hardware?  Intel built the video chipset & driver, which seems to be at least part of the problem.  The SP4 has been out for about less than 3 months, btw.
    2016-01-19T06:31:53+00:00
    Well I did it and so far so good.  Annoying downside though is that the short cut to extend the screen or duplicate it to a monitor no longer works! In fact I can't get my monitor to work at all...
    2016-01-19T12:01:32+00:00
    This problem, which has been intermittent has suddenly, since yesterday, become much worse requiring power off/on several times a day. No idea why it suddenly got worse as I do not see any new updates in the past few days. Before this I did not have to reboot for almost 2 weeks. Hoping for a fix soon.
