2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-17T20:08:49+00:00
    I really don't get these instructions. For my SP4 holding down the power button for about 10 seconds turns it off (like any modern PC) and the 2 buttons boot up into "BIOS" mode.
    2016-01-17T20:17:33+00:00
    I am 100% up for it I just need to find the time to trawl through the 49 pages of the thread to find the instructions.
    Cheers
    2016-01-17T20:43:09+00:00
    Cheers
    Try page 42 :) Page 42
    2016-01-18T09:32:43+00:00
    You're a top man thanks.
