2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-16T15:08:25+00:00
    This works for my surface pro4. Anybody have this problem should give it a try.
    And please rate helpful at page 42 if it works.
    2016-01-16T19:15:29+00:00
    I'll start by saying what a beautiful machine the surface pro 4 is...  However, it is unreliable.  I work in a profession where I need to be able to wake my machine up from sleep mode and for it to respond consistently; and my problem is it doesn't. I would say it doesn't even do it the majority of the time.  On the power settings I have go to 'sleep' when I press the button or shut the lid.  This means I expect when I push the button again it will wake up but it doesn't. The keyboard wakes up but the machine doesn't That leaves me with the inconvenience of having to force a restart and the time wasted associated with doing that.  Can anyone help?!?
    JR
    2016-01-16T20:49:37+00:00
    Don't use Sleep until Microsoft releases the next Video driver update which should fix the problem.
    Until then use Hibernate.
    If you are interested there are a number of long threads in this forum which discuss and complain about this issue ad nauseum. Here's one:
    http://answers.microsoft.com/en-us/surface/forum/surfpro4-surfdrivers/surface-pro-4-screen-wont-wake-from-sleep/aed66dc7-289a-4300-a167-ab8394b7df06
    2016-01-17T06:04:52+00:00
    I also had this problem. When this happened to me in the past, I would hold down the power button and wait for it to turn off. A interesting thing i found out is that the touch screen still works, thus you can hold down the button for three or whatever seconds then swipe down to turn off the compute and turn it back on. Although for the surface pro 4 people, you will need to turn on windows hello to unlock the computer. Otherwise it may be very difficult to unlock the surface.
    Why is it that the surface doesn't give you the visuals but the touchscreen still works? Shouldn't they work together?
    Bode
