2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-13T13:23:20+00:00
    Have you installed the .4352 driver update discussed over the last few pages here?  I haven't had a wake from sleep issue since I installed it around 2 weeks ago.
    2016-01-13T17:23:39+00:00
    Todays Windows update "Cumulative Update for Windows 10 Version 1511 for x64-based Systems (KB3124263)" has made waking from sleep much better! Note the KB only mentions security fixes.
    I can now open and close the cover and the shift key almost always wakes the Surface up (including Hello login). Once I got the keyboard backlight on and a black display but closing and opening thne cover fixed it. I tried with and without external HDMI monitor and USB dock connected monitors, mouse, ethernet etc). I do get the no responsive "do you want to enter tablet mode" toast when no monitors are connected.
    This is good! :)
    @Microsoft. Thanks for fixing but you have treated us in a very poor way indeed! When Windows 10 launched I was really excited by the responsiveness of Microsoft support (mainly via Twitter). So much so I called out the "new listening Microsoft". That made me very happy. But now that has vanished and we are again being treated to stony ignorant silence. Have the lawyers or PR bunnies taken over again?
    This is bad! :(
    2016-01-13T19:32:10+00:00
    Wow that actually worked! Thank you very much.at first I got worried about my new surface pro 4 but then I tried it and it worked!!thanks!
    2016-01-13T19:56:01+00:00
    This is good! :)
    This is bad! :(
    Disagree. There is no drivers or fix for these issues in this update.  You are mistaken.
