2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-13T04:19:01+00:00
    Thanks! I'll give it a try if the black screen coming out of hibernation happens again.
    It appears that the latest Microsoft Updates today (2015-01-12) has had a positive impact on many things. It's very early but so far things have been much better connected to the new docking station with 11-20 .4326 Microsoft drivers vs 12-15 .4352 Intel drivers.
    On Intel sourced .4352 drivers new corded docking station before latest Windows Updates SP4 would disconnect about every 10-15 minutes momentarily then switch back to external single 4K monitor but I'd have no mouse or keyboard. So I'd disconnect docking cable and reconnect.
    Before using Intel .4352 drivers I'd have a similar but less frequent experience but I'd loose docking station wired Ethernet adapter every 10ish minutes.
    So I've installed latest update, including .63 and rolled back to latest Microsoft display drivers (.4326) the docking station issues have so far not occurred! I'm overjoyed.
    I'll do more testing over the next several days - hopefully the black screen issue is a thing of the past too, even with November drivers.
    2016-01-13T11:37:01+00:00
    But we can't rely on that solution every time this occurs.
    2016-01-13T13:14:51+00:00
    It is now January 2016 and the Surface Pro 4 STILL won't wake up much of the time. I am about to return my device for a refund and stick with my Surface Pro 3.
    2016-01-13T13:22:46+00:00
    Hi guys,
    These 3 first weeks with my Surface Pro 4 i7/16gb/256gb as my work computer has been frustrating.
    Some of the problems are gone, but the biggest one and most frustrating is still here.
    So my setup is:
    2 offices with the following setup:
    2x Samsung S24c650 monitors
    1x Surface Dock
    2x Mini DP to DP cable.
    i come to work at one of the offices, plug my surface in to the dock, boot up, everything is fine.
    go get a coffee, a trip to the toilet, meeting etc:
    Surface has turned of its screen (which it should do)
    wake it and only the surface wakes up, when i check the display properties it still show the monitors as connected(and apps/windows may open on the other screens), but i cant get a picture even if i turn them on manually and choose the right input. still just a black screen. disconnecting the dock and connecting again does not work either.
    only thing that works is to reboot again, sometimes i need to do it a couple of times. disconnecting the dock and connecting again does not work either.
    and it's the same in both offices
    Anyone found a solution or easier workaround?
