2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-10T01:15:49+00:00
    I did try it but the computer won't allow me to install the driver manually. Whatever I try it keeps saying the current driver is the best driver and it won't update with the downloaded driver from Intel. Any suggestions around this?
    2016-01-10T01:30:57+00:00
    Did you follow my instructions fully? You need to manually force the driver install. Check my instructions again for how to do that. I even included screenshots.
    2016-01-10T03:27:58+00:00
    I'm now seeing that if I leave my Surface Pro 4 on at my desk and it puts itself to sleep, then I can not get it to wake back up.  It's the i5/256/8GB model with a Type Cover on it and nothing else.  When I try to wake it, the keyboard will light up and thats it.  The only way to then bring it back from the dead is to hold down the Power Button and Volume Up button.   At that point I am brought into some device setting menu and then if I exit I am then rebooted back into Windows.  The latest update from 11/2/15 was applied that night.
    Anyone else seeing this problem?
    I have experienced this same scenario twice and I can count on one hand the times I have used my SP4. I'm concerned that it may never wake up. I have hopes that there will be a fix released to ease my worries. It was a gift for my new startup business. I don't want to return/exchange it and half to go through the setup again.
    2016-01-10T07:23:30+00:00
    The black screen issue is much better with the new driver. However, it is not completely gone. I still had a black screen yesterday after closing the keyboard (standby when lid closed is disabled). Putting the surface into and out of standby several times finally turned the screen back on.
