2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-07T18:51:28+00:00
    Hi Loren, it may be possible to use a special Windows key sequence to wake the screen. Try this:
    • If you have a keyboard connected, press Windows logo key + Ctrl+Shift+ B
    • If you are in tablet mode, simultaneously press both the volume-up and volume-down buttons, 3 times, in quick succession (within 2 seconds).
    If Windows is responsive, you should hear a short beep while Windows attempts to refresh the screen.
    Hope that helps,
    Greg
    2016-01-07T18:52:24+00:00
    Several or maybe many of the Surface Pro 4 users have encountered an extremely vexing problem: the device dos not wake up after going to sleep when the keyboard cover is closed even for a minute or so.  I have read quite a number of posts in this and other forums about this very issue and suggested solutions which do not work all of the time.  I like many other Surface Pro 4 users know that the Microsoft Surface Pro 4 Support team do their very best to help us out and you deserve a great big THANK YOU.
    It's been about 2 hours now that I have tried unsuccessfully to bring my device up to life, to no avail.
    If you have not done so, please, please, please, do inform the device hardware/software engineer builder teams that this is a major problem that needs to be fixed and fixed promptly.  It doesn't affect just me, it seems to affect a ton of users.
    I purchased the device to be able to work on it because it received rave reviews and I have been an MS user for many years.  However, if this now 1 month old device cannot even wake up, it cannot be used and it becomes an expensive and totally useless computer.
    It is not the fault of you, the Microsoft Surface Pro 4 Support team and Thank You again for your help, but please pass on this very deep frustration all the way up to the CEO if need be.  We ask that the problem be fixed, lest we go somewhere else for our computer needs after returning the device to Microsoft for a full refund.
    Thank you.
    2016-01-07T20:31:17+00:00
    Hello.  I have a surface Pro 4 that is suffering from being stuck in sleep after closing the lid many times per day.  I have rebuilt and updated many times and the problems remain.  It appears this is a known issue and still has no fix.
    What is the status of this update?  I consider this device unusable in it's current working state.  On top of this I am being asked to purchase these devices at my place of work where i am an IT manager and I am having to say absolutely not.
    When will we see an update to fix this very serious issue.  I see the post at the top of the forum apologizing but what good is an apology if you don't fix it!!!
    2016-01-07T22:34:34+00:00
