2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-05T16:47:06+00:00
    I haven't seen this update on my SP4.  It's not installed, and no updates are available.  Is it a Preview Build?
    Might be a Regional flight issue. I'm in UK and also have seen no such update.
    I now have a new problem with fan going on fast when goes to sleep
    2016-01-05T23:50:12+00:00
    This happened to me but instead the Windows Hello infrared light came on.
    2016-01-07T17:34:29+00:00
    This is driving me insane. I love this device WHEN IT WILL WAKE UP.
    I tried going into settings and changing it to your Sleep and Screen off settings but it didn't fix anything - I didn't see any options for Hibernation. Am I missing something?
    2016-01-07T17:35:46+00:00
    Also, I've noticed that problem happens most often when I hit the power (sleep) button to turn it off THEN close the type cover. A few seconds after I close the cover I'll hear the notification sound, which I've always thought was odd. Seems like the problem is worse when I do this but I do it so much out of habit.
