2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-04T23:21:55+00:00
    Windows key + P has not worked for me, ever.
    2016-01-04T23:28:36+00:00
    Hi Jordan,
    Try the following settings for sleep and hibernate after (so far I haven't had any black screen issues):
    On battery: screen off 5 minutes, sleep in 15 minutes, hibernate after 15 minutes (or less) of sleep mode.
    On power (plugged in): screen off in 5 minutes, sleep in 3 hours, hibernate after - never.
    I'm sure these could be played with a bit. For me sleep is not the problem, hibernation is - especially after long sleep and hibernation times. It doesn't make much sense but for me I haven't had a black screen event yet with the above settings.
    I'm curious to know if anyone else has success with these settings.
    2016-01-05T00:07:40+00:00
    Hi Jordan,
    I just changed mine to see what happens.
    2016-01-05T01:59:47+00:00
    I'm getting a bit confused with two different "solutions." The current display driver 20.19.15.4326...is that a new one?  Is that the "fix"?
    If not, and I have not challenged it yet, I have the following settings working just fine.  But I disagree with Loren about Hibernate.  My experience and I thought I read this too, is that Sleep works fine until 1 hour.  So I have my settings as he does, except I leave it on Sleep for up to an hour (maybe a few minutes less) , and then Hibernate. That has worked just fine.  The only difference I have for battery is screen off sooner.
    That said, I don't like using hibernate, as I think sleep wakes faster and is less hard drive intensive.  So, I would like a fix!
