Earphone with du-du-du sound when audio is paused
2015-12-30T09:05:56+00:00
When I pause any audio (either local or online music), the earphone begins to produce the sound like "du-du-du-du...".
Is there any solution? Thanks for your attention.
Surface | Surface Earbuds | Settings
    2015-12-30T16:43:35+00:00
    Hi MiikeTsui,
    Thank you for sharing your experience here.  Do you hear the same thing while using the built in speakers? Have you tried using a different pair of earphones?
    Kind regards,
    Clare
