Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-06-04T19:50:22+00:00
    Yes , I also use VPN & I just turn wifi and reboot problem slove
    2023-06-05T03:58:18+00:00
    Turning off WiFi, bluetooth, etc doesn't do anything for me. The only thing that works is connecting it to the charger. Then it will stay on. Also, the battery gets extremely hot. All this started after the update.
    I can't find a way to contact support about the issue. And when I tried to submit a service repair online, the site says that physical damage isn't covered.
    2023-06-05T08:12:41+00:00
    Wow. The charger! And, I believe you!
    This bug is a weird one, seems to affect different devices and setups differently. "It depends!"
    Many people have NO problems!
    Might be harder to figure out the fix.
    Anyway...
    Are you on Duo 1 or 2?
    Do you use a VPN?
    Thanks. I'm just curious.
    While it would be interesting to learn the causes and solutions, I'd really, really want a fix, and soon. Who doesn't!?
    2023-06-05T08:50:53+00:00
    The charger truck doesn't seem to work for me, even if it did, the screen is so buggy when charging I can't use it.
    The WiFi and VPN does make sense though. I thought it was odd that it only seems to do it after I got home at night 😅
