Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-07-16T09:03:25+00:00
    Same problem.
    Some apps are distorted.
    And ms start is flickering (it did this already before the update).
    2023-07-16T11:17:54+00:00
    Getting issues on some apps like FB & Messenger. The screen flickers when trying to delete a message in Messenger. When adding pics in Marketplace, the next button is missing unless you go full duo screen.
    2023-07-19T02:23:17+00:00
    My Duo 2 is dead as a door nail now! It only starts periodically and I can never predict when. If it does boot up, the back of the right panel gets very hot. My phone has been inoperable since June 8th. I was "lucky" enough to get the Duo started once and downloaded the June update, but it has not solved anything for me.
    Too bad. I loved my Duo 2 and everyone was jealous of it. Not so much anymore, lol!
    2023-07-21T17:21:26+00:00
    I also went through the huge hassle of "Recovering" my Surface Duo 2 as someone suggested to no avail. Still having the reboot recycling, unpredictable starting and only when plugged in.
