Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-06-28T16:45:57+00:00
    I am now getting the message that "Updates are temporarily unavailable. Try again later." after I plugged in to another charger and was finally able to get past the cycling Windows logo. It says that the last successful check for updates was Jun12 and the latest Android security update: May 1, 2023.
    Strange; i got the 27th June update and it booted normally.
    Try to update en reboot manually.
    2023-06-28T17:02:59+00:00
    Great! It's now stuck on this for a while. Quality work, Microsoft!
    2023-06-29T03:06:12+00:00
    Geez! I would love to just be able to get to this screen!
    2023-06-29T03:09:41+00:00
    Have you tried recovery options?
    Impossible! The Duo 2 doesn't boot most of the time. I have never been able to do anything from the "Step 3" in the recovery process since the Duo 2 will not power on.
