Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-06-28T07:33:45+00:00
    My Surface Duo 2 only does 7 cycles of vibrating, showing the Windows logo in left-hand screen for a few seconds, and then shuts down. I can't get past this cycle even when plugged in.
    What to do?
    Obviously, can't get update installed in this scenario...
    2023-06-28T08:11:18+00:00
    Have you tried recovery options?
    2023-06-28T08:33:05+00:00
    UPDATE:
    The SD Update dates june 27 fixed the problem obviously. At least since 24hrs no OS crashes while connected to mobile AND wireless network.
    2023-06-28T14:07:26+00:00
    I am now getting the message that "Updates are temporarily unavailable. Try again later." after I plugged in to another charger and was finally able to get past the cycling Windows logo. It says that the last successful check for updates was Jun12 and the latest Android security update: May 1, 2023.
