Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-06-10T17:06:41+00:00
    Is there a solution to rollback the update or go to previous version? Any image of device firmware with previous version? It would be great.
    Or is there a official microsoft hotfix update to patch and fix the problem?
    2023-06-10T17:18:56+00:00
    I did that and it didn't work for me. Last night I unplugged the phone and it had to be plugged in again for over 30 minutes before it randomly turned back on. Weird....
    2023-06-10T17:31:40+00:00
    May 31, 2023
    Thank you for reporting this issue.  We are actively investigating.
    Jeremy,
    Could you also actively give us an ETA for the fix? Or should we just get new Samsung, Pixel or other foldables now?
    2023-06-10T21:50:30+00:00
    I think Microsoft is 0 for 3 on those questions and has struck out swinging thus far....
