Surface Duo 2 - permanent reboots after Update may 30 2023
2023-05-31T05:50:14+00:00
DId anyone else experience random shutdowns and/or reboots not coming up again after the update may 30 2023? Display showing the option of retrying oder factory reset.
Saw also some postings on reddit regarding this new issue.
Surface | Surface Duo | Performance and maintenance
2023-05-31T17:08:24+00:00
Updated June, 27 2023
Thank you for your patience while we have investigated Surface Duo devices that would restart after the May 30th, 2023 update. The June 26th, 2023 update improves system stability. See Update Surface Duo for more info on how to update your Surface Duo or Surface Duo 2.
Marking as "Answered" for now to raise visibility.
133 additional answers
    2023-05-31T12:09:58+00:00
    Getting same error in Surface Duo after latest update. Have had several restarts already. Latest update broke something.
    2023-05-31T19:22:51+00:00
    Just turn off the Wifi
    there is a bug, use data and wait for an update
    Best
    2023-05-31T19:49:12+00:00
    Settings -> System -> Reset Options -> Reset WiFi, mobile & Bluetooth
    Worked on my Duo2 - the wife's Duo1 and solved the issue for both.
    It's been mentioned to turn off vpn's as this seems to be directly related to the reboot crash.
    Seems to fix the issue - not my discovery just moving it along from Reddit to here.
    Marking as answered is horrible considering and answer wasn't provided.
    2023-05-31T20:13:23+00:00
    Done that this afternoon. Worked for some hours. Now had two shut downs in a row. Hsppend after digital wellbeing switched to night mode and I paused it for 30 min snd additional turned die n notifications again. After that the OS crashed twice. Now I stay in night mode and no notifications and all up and running. For noe...
