Approved List Here https://www.microsoft.com/surface/en-us/support/hardware-and-drivers/troubleshoot-docking-station-surface-dock
Check your monitor’s compatibility
Monitors that aren’t supported with Surface and Surface Dock
The monitors listed below have connection issues with Surface and Surface Dock. We are working with third parties to resolve these issues and will update this page when new information is available. If you’re using a monitor that isn’t listed below, try
the solutions below to resolve the issue.
| Acer |
XB280HK |
| AOC |
G2460PG |
| Dell |
U2312HM (FW A05) <br><br>U2212HMt <br><br>U2412Mb (FW A01) <br><br>U2412Mc <br><br>U2414Hb (FW A00) <br><br>U2515Hc (FW A01) <br><br>U2715Hc (FW A00) <br><br>U2913Wm (FW A03) |
Monitors known to be compatible with Surface and Surface Dock
We’re always working to improve and add to the list of monitors that we know to be compatible with Surface and Surface Dock. The following DisplayPort-capable monitors have been tested for compatibility with Surface and Surface Dock.
Note
Check the firmware version installed on your monitor. Go to your monitor manufacturer’s website to learn how to find your monitor’s firmware version.
| Acer |
B286HK <br><br>S277HK <br><br>T27HUL |
Lenovo |
PRO2840mD <br><br>ThinkVision 28 |
| AOC |
G2460PQU <br><br>G2770PQU <br><br>q2963Pm |
Samsung |
S27D590CS <br><br>S27D850T <br><br>S32D850T <br><br>U28D590D |
| ASUS |
PA279Q <br><br>PB278Q <br><br>PB287Q <br><br>VG248QE |
ViewSonic |
VG2860MHL-4K <br><br>VP2780-4K |
| BenQ |
BL3200PT <br><br>BL3201PH <br><br>SW2700PT <br><br>XL2420Z <br><br>XL2720Z |
| Dell (model and firmware version) |
E2014T (FW A01) <br><br>E2416Hb (FW A00) <br><br>E2715H (FW A00) <br><br>P2210T (FW A00) <br><br>P2314Hb (FW A00) <br><br>P2414Hb (FW A06) <br><br>P2415Qb (FW A02) <br><br>P2416Db (FW A00) <br><br>P2715Qt (FW A03) <br><br>P2815Q (FW A03) <br><br>U2413f (FW A02) <br><br>U2415b (FW A02) <br><br>U2713Hb (FW A07) <br><br>U2713HM (FW A00) <br><br>U3014 (FW A02) <br><br>U3415W (FW A01) <br><br>UP2414Qt (FW A02) <br><br>UP2516Dt (FW A00) <br><br>UP2716D (FW A00) <br><br>UP3214Q (FW A00) <br><br>UP3216Q (FW A00) |
Note
This list was based on our internal use of the respective monitor and adapters with Surface Pro and the Surface Dock on February 10, 2016. Any firmware changes made by monitor and
adapter manufacturers at a later date may cause new issues unknown today.
This list is provided to you for reference and informational purposes only and in no way is Microsoft providing any guarantees or warranty that any of the mentioned monitors or adapters will function properly with your Surface device, nor is Microsoft advocating
the use of any of the mentioned monitors or adapters in any manner.
This list should not be interpreted to be a commitment on the part of Microsoft and Microsoft cannot guarantee the accuracy of any information provided. Microsoft makes no warranties, express, implied or statutory, as to the information on this page. You agree
to use this list at your own risk and agree that this list does not override, add to, or change the warranty terms that come with your Surface device. If you cannot agree to these terms, do not use this list.
