New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
    2016-03-02T13:58:38+00:00
    Tried different cables and that did not make any difference.  Same issues.
    Every morning when I come back to my computer I can not get any screen to turn on. I have to hold the power to restart the surface.
    2016-03-02T15:40:51+00:00
    So I bought the "Cable Matters" HD cable on the compatibility list you sent and it seems to help a bit but still lots of issues.  Mostly I get black screen on the Samsung when it comes out of sleep.  I have plugged to mini-DP on both dock and SP4 with similar results.  Interestingly, this morning I had this issue and it was plugged into the SP4 and I couldnt get the Samsung to wake - i unplugged mini-DP, power cycled monitor - nothing.   Then I moved the mini-DP to dock and the Samsung came to life.  All very wierd.  I dont feel like it should be this frustrating for something that should just work and has worked on many laptops for many years.
    2016-03-04T12:30:39+00:00
    So is there any fix at all from Microsoft? We as corporate are stuck! We have a bunch of Surface Pro 3s and 4s and none of them are working since we had to switch to the surface dock. We've got Windows 8 running and have tried both active and passive adapters and the same thing happens each time. Plug it in, Surface starts flickering, monitor does nothing, etc. Only tried DVI to MiniDP because VGA isn't an option with our monitors. Thoughts.
