New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
    2016-02-23T17:04:10+00:00
    hey there,
    Any luck with this?  i have same config and having nothing but trouble with the monitor waking from sleep...
    Received the new Dock yesterday and started messing with it this morning. I am having the same issues, nothing has changed.
    The main issue I am having is whenever the Surface Book shuts off the monitor my Samsung flashes every 2-3 seconds.  That's the main issue I am noticing.  I can however go on about other issues such as it not handling high DPI scaling very well when docking and undocking.  I have also seen where it just didn't want to wake up.
    I do notice that in my "Devices and Printers" list it shows a unspecified "3D Video Controller" there. Not sure if that has anything to do with any issues.
    I do not know what to try anymore. truly annoying.
    yes, its super annoying.  I have been dealing with this on my sp4 since October.  I am on my 3rd dock and 2nd Surface so I am convinced it is not specific to my unit.  A workaround that seems to work is to enable hibernation and hibernate it instead of sleeping.  You need to hibernate around 20 mins so that the undocumented sleep features of the processor don't kick in first.  I am experimenting with just connecting the monitor to the displayport on the Surface instead of the dock, but that really just gives up on the dock...
    I havent seen the 3D video controller device - it must be related to the discreet graphics of the surface book which the SP4 doesn't have.  Definitely you should make sure the proper drivers are installed for that.
    2016-02-23T18:38:51+00:00
    Have you looked into cables at all? I bought the one that Microsoft says is ok, on this list. Troubleshooting
    The reason I ask is I decided to go buy a few more cables, figured I could return them.  When I started reading I started to see this VESA 20th pin thing...   If you read the reviews of this cable one person touches on it.  Accell Cable
    I am going to try a few other cables.  I tried a different one I had laying around and it didnt make a difference but I am desperate now.
    2016-02-27T19:45:27+00:00
    I have had the same issue with surface pro 3 and surface dock since December. The only way it works is with the expensive mini display port to vga adapter sold at Microsoft store. The resolution is terrible...
    I have had Microsoft replace this dock and it still doesn't work. If I could return it, I would return it.
    I cannot believe Microsoft will not provide a solution or offer an update to let us know they are working on the issue.
