New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
    2015-10-28T18:30:57+00:00
    I agree with gaforrest. I had already visited the step of updating drivers as well, and definitely with the SB connected to the dock.
    Right now I'm wondering if the SB drivers are finnicky with cables being used. I have mini displayport to displayport calbes, and HDMI to mini displayport. In neither case does everything work right, but I get different problems depending on cables. I'm considering ordering some cables from various vendors to see if I get different results. If so, I wonder if it's pin 20 compliance being fickle or something else along that line. Sucks that nothing comes with DP cables and vendors are really inconsistent.
    2015-10-29T00:50:20+00:00
    So what is the Mini DisplayPort to HDMI Adapter? Is this active or passive? Is there another adapter if it is passive? I bought a Dock and after looking at it and realizing I still needed an adapter for the video and reading the entries here....I took it back today.
    M$ just doesn't seemed to have worked all this out.
    I'm waiting for the Lumia 950XL and can't get a believable estimate on when it will be available. And then there's the dock for it which doesn't have an ETA.
    Arrrrrrrgggghhhhh!!!!!
    2015-10-29T04:49:20+00:00
    I think the Microsoft mDP to HDMI is a passive adapter, though I'm not certain. I have an active one coming from Amazon tomorrow, so I'll test it. If it doesn't work, I'm returning the dock. I don't understand why it doesn't work properly, as everything worked fine with my surface pro 3 dock. As far as the Lumia 950XL, an employee mentioned it would be coming out next month, but nothing more.
