New Surface Dock Does Not Work via mini displayport to HDMI & DVI
2015-10-27T17:18:04+00:00
The specific device I am referring to, is the new Surface Dock for Surface Pro 3/4 and Surface Book. I have described the issue here on Reddit, and a number of others are also experiencing the same problem. Basically, the new dock doesn't work when the monitor is connected using mini displayport to HDMI. The monitor is detected correctly and the correct resolution is set, but the screen remains black. In my case, I randomly get some image on the monitor, but it's compressed to one side of the screen and garbled. The mini displayport to HDMI adapter works properly when connected directly to the Surface, so the adapter itself is fine. If I instead connect the mini displayport to VGA adapter to the dock, the monitor displays correctly. I have tried using a straight mini displayport to DVI cable and the issue remains. Additionally, I have connected a Surface Pro 3 to the dock and experience the same issue.
So to summarize, the dock does not function correctly when using a mini displayport to HDMI adapter to connect the monitor, but does work with a mini displayport to VGA adapter. This problem is repeatable using both a Surface Book and Surface Pro 3.
2015-10-29T17:45:57+00:00
I purchased an active mDP to HDMI adapter from Amazon (Plugable is the brand) and so far the external monitor is working correctly through the dock.
Moderator Edit (11/3/2015):  If you are using a passive MDP to DVI adapter and experiencing difficulties, you may need to switch to using an active adapter.
If you switched from a passive to active adapter and continue to experience difficulties using Surface Dock to display to external monitors please consider making some changes to your cabling: different lengths, different quality, different adapters, etc.  If adjusting your cabling fails to resolve please consider sharing the following:
  1. Make and model of external displays
  2. Make/model of adapters if present
  3. Make/model of cables
For more troubleshooting info and steps to confirm your Dock is updated, please view our Troubleshoot Surface Dock article.
Thank you,
Josh
2017-05-22T09:18:50+00:00
 We suggest that you contact our Surface Answer Desk team for further assistance or visit the nearest Microsoft Store if you are in the US. In case you're offshore, contact our Global Customer Service team.
315 additional answers
    2015-12-16T15:31:18+00:00
    Do you have a link to the one you used that is working?
    2015-12-16T15:50:42+00:00
    I am not sure by what you mean on a link. I provided the link to a thread where I tried out a solution and it worked. If you are referring to the cable, i just used the mDP to DP cable provided with my Dell monitor.
    2015-12-16T16:13:52+00:00
    I took my SB4, dock and dongles to the local Microsoft store (they opened a store front in our local mall for the Christmas rush).  Attached all to their HDMI 4K monitors and all worked fine. We even dropped the resolution to match my monitors (1680 x 1050). All I can surmise is the dock cannot handle the passive HDMI to DVI converters I use for my DVI monitors, however, the SB4 is able to drive either monitor when plugged directly into the SB4.  My next step is to purchase 2 new HDMI monitors.
